[Revue] Seiko SUN021P1 - PROSPEX KINETIC GMT DIVER'S
chezjoe
Message par chezjoe »
Seiko SUN021P1 - Image KINETIC GMT DIVER'S
aujourd'hui je viens vous présenter la "petite" dernière, elle répond au doux nom de Seiko SUN021P1 - PROSPEX KINETIC GMT DIVER'S. Cette montre s'inscrit dans la nouvelle gamme plongeuse moyenne gamme de la marque qui se nomme Prospex.
Un peu plus d'explication sur la gamme, tiré d'un communiqué Seiko lors de la Baseworld 2014 (http://www.seiko.fr/fichiers/communicat ... x_0205.pdf)
Seiko Prospex. Serious watches for serious sports For true watchmakers, adventure sports, whether on the sea, on land or in the sky, present the greatest challenges of all. Since Seiko made its first diving watch in 1965, Seiko has been exceeding the expectations of those whose sports require watches with truly professional specifications. Now, Seiko Prospex brings together all Seiko’s sports watch expertise in one collection.
From 1,278 timing devices in 1964 to pioneering in sports watch technology. In 1964 , Seiko announced itself on the world stage of sports timing technology with a whole new generation of timing and scoring devices that set a new standard. The multi-sport suite of timing, scoring and display systems comprised no fewer than 1,278 devices in all. Ever since, the challenge of sports has inspired Seiko to create new technologies, new materials, new functions and new display systems to serve the needs of true sports enthusiasts worldwide.
In particular, Seiko pioneered several features in diver’s watches that are now widely accepted as setting the global standard, including the ‘accordion’ or corrugated style strap, the wide arrowshaped hands for extra legibility, and the two-piece case construction for added security. Similarly, in aviation watches, Seiko invented the trigonometric slide rule that allows pilots to make complex calculations in flight.
With its new Diver’s and Aviation watches, Prospex is the latest expression of this long tradition.
The Prospex Diver’s watch. The new Prospex Kinetic GMT Diver’s uses the same double case system as the legendary 1975 model, but it does so in a modernized and stylish way. As the name Prospex implies, it has a professional specification, with 200m water resistance, but it also has a design flair that makes it unique, as is clear from the window in the side of the outer case through which you can see the inner case.
The dial is designed uniquely with legibility in mind. The professional level of the specifications becomes clear when you study the details, the 3 dimensional hour markers, the anti-reflective coating on the sapphire crystal and the precise and secure operation of the uni-directional bezel.
The caliber is Kinetic, the perfect technology for diving as it combines 1 second a day precision with the certainty of Seiko’s unique no-battery-change Kinetic technology.
It is available with a steel bracelet or with a silicon strap, designed for strength, flexibility and longevity. The Kinetic GMT Diver’s is true to the Seiko tradition, but is updated with the very latest in design and technology.
The Prospex Aviation Solar Chronograph
The Prospex Aviation Solar Chronograph is a modern reinterpretation of a Seiko classic. In 1972, the Seiko Flight Computer set a new standard in aviation watches and began a tradition in this area that is today renewed with a solar aviation chronograph of high specifications. The slide rule allows calculations of distance, fuel and oil consumption and speed, while the chronograph measures elapsed time for up to 60 minutes. Powered by light alone, this remarkable watch delivers what pilots need most, complete reliability
throughout their flight.
Perfect timing and reliability on the sea, on land and in the sky. Adventure sports know no boundaries. Whether for use on the sea, on land or in the sky, the adventure sports enthusiast will find the Prospex watch that meets the challenge and delivers precision and reliability in even the most adverse conditions. Prospex is built to perform and built
to last. The collection is broad in the range of sports watches it includes, incorporating all Seiko’s technologies, Kinetic, solar, quartz and mechanical, and in its price range, with models starting at 300 Euro and going up to 3,000 Euro for the 1000 meter saturation diving watch. Seiko Prospex is Seiko’s first new mainstream Elite collection for seven years and takes its place alongside Sportura and Velatura as an important new reference point in the world of sports watches.
[center]Seiko SUN021P1 - Image KINETIC GMT DIVER'S[/center]
Il s'agit donc d'une montre de plonger à mouvement Kinetic et une aiguille GMT sur 24h, pour pourra servir ou de second fuseau horaire ou vous permettra d'avoir l'heure sur 24h.
Je dois dire que dès son arrivée, j'ai été séduit par la forme et les découpes assez inhabituelles de la lunette et du boitier et malgré des dimensions assez imposante, je trouve la montre parfaitement équilibrée.
Tout d'abord les caractéristiques de cette Seiko
Modèle: SUN021 Diver’s Kinetic
Mouvement:
5M85 Kinetic GMT
Mouvement animé par le mouvement du corps
Réserve de marche: Environ 6 mois
Indication de la réserve de marche par pression sur le bouton du haut.
Réglage facile de la fonction GMT
Précision: +/-15 seconds par mois (dans un environnement dont les températures vont de 5℃ à 35℃)
Boitier:
Diamètre: 47.5mm
Boîtier en acier inoxydable
Résistance à l'eau: 200m
Band
Bracelet caoutchouc avec boucle acier brossé
Verre
Glace saphir
Quelques explications sur le fonctionnement du mouvement Kinetic
ALIMENTÉ PAR VOS MOUVEMENTS
La première montre à quartz au monde est à peine sortie quand les ingénieurs SEIKO se lancent un nouveau défi : inventer une montre à quartz qui générerait sa propre énergie. La clé du succès technologique est de réussir à créer un maximum d'énergie et de réduire au minimum sa consommation. En 1988, avec 50 dépôts de brevets, le but est atteint : SEIKO crée la montre Kinetic.
ALIMENTATION ÉLECTRIQUE
Le générateur miniature Kinetic renferme un rotor suspendu par lévitation magnétique. Il peut atteindre jusqu'à 100 000 tours / minute, soit 5 fois plus rapide qu'un moteur de Formule 1. La première montre Kinetic ne consommait que 0,9 microwatt d'électricité, soit 3% de l'énergie nécessaire au fonctionnement de la Quartz Astron. Aujourd'hui, la Kinetic Direct Drive ne consomme que 0,71 microwatt.
FONCTION KINETIC DIRECT DRIVE
Porter une SEIKO Kinetic, c'est déjà un « pouvoir », celui de lui donner vie simplement en bougeant. Avec une SEIKO Kinetic Direct Drive vous pouvez visualiser en temps réel l'énergie que vous avez produite. Il vous suffit de tourner la couronne et l'indicateur de réserve de marche vous affichera la quantité d'énergie produite. Simple d'utilisation, cette nouvelle technologie SEIKO est interactive.
FONCTION KINETIC AUTO RELAY
Imaginez une montre capable de se mettre en veille, de se réveiller et de se rappeler du temps. Les ingénieurs SEIKO l'ont réalisée. Pour augmenter la réserve de marche des modèles SEIKO Kinetic au-delà des quelques mois habituels, ils ont imaginé un système de mise en veille de la montre. Celle-ci fixe ses aiguilles si la montre n'est pas portée, elle « se réveille », se rappelle du temps, transmet l'heure aux aiguilles qui tournent sur elles-mêmes et se remettent automatiquement à l'heure exacte, même après 4 ans d'immobilité. Pour que ce rêve ait pu être réalisé il aura fallu une grande tenacité et la technologie horlogère la plus pointue. C'est ainsi que naît en 1999 la Kinetic Auto Relay, fonction qui est actuellement intégrée au modèle Kinetic Perpétuel.
Liens vers la notice: http://www.seiko.fr/fichiers/manuels/5M85.pdf
Place aux photos:
Re: [Revue] Seiko SUN021P1 - PROSPEX KINETIC GMT DIVER'S
Suis dans le train et j en profite : superbe revue !
Très belle revue et très complète, j'ai pas encore tout lu :oops:
Je la trouve vraiment sympa mais trop grosse pour moi ;)
Superbe, merci Joe pour cette belle revue très documentée :jap:
Dommage pour le diamètre ça aurait pu être ma tool watch pour cette été car je la trouve vraiment bien, mais bon tant pi.
Profite bien ;)
Retourner vers « Seiko »
