[Revue] Precista PRS-5
chezjoe
Message par chezjoe »
Precista PRS-5
Voici une montre que je cherchais depuis un certain temps, malheureusement la fabrication a été arrêté avant que je me décide à en faire l'acquisition. Après un an et demi de recherche, je n'ai pas hésité longtemps quand je l'ai trouvé dans une annonce.
Quelques échanges plus tard avec le vendeur et l'affaire est conclue... Me reste plus qu'à patienter quelques jours le temps de la livraison.
Je sais que la montre est en super état et qu'elle est montée sur un nato vintage.
En attendant la livraison, je me documentes sur la belle, en commençant par le site Anglais qui distribue la marque, plutôt que de traduire de manière approximative, je vous laisse faire :mrgreen:
This is the second PRS-5 model to be produced by Time Factors, the first was under the name "Broadarrow"in the style of the Hamilton military chronograph and fitted with the Poljot 3133 movement. Following restrictions on the use of the name "Broadarrow", the PRS-5 lives again as a "Precista" and is now fitted with the Seagull ST-19 chronograph movement.
The Seagull factory has been manufacturing movements since 1955 and have long been the favourite movements for replica watches. The ST-19 is a 19 jewel column-wheel chronograph, allegedly identical to the Venus 175 movement and made on the same machinery, which the Chinese acquired when the Venus 175 went out of production. Others claim that the Seagull was simply reverse-engineered from the Venus and the argument continues over which story is correct: either way, the fact remains that the design retains all durability of the original Venus.
The PRS-5 has a 31mm visible dial with Super Luminova "dot" hour markers and also a luminous 6 & 12. The crystal is a hi-dome acrylic crystal, 3.4mm high. The semi-recessed signed crown measures 4.0mm high by 7mm diameter. The hands are painted white with Super Luminova filling. The watch is water resistant to 50 metres, is fitted with a screw back and has 20mm drilled lugs.
timefactors watches
MODEL: PRECISTA PRS-5
CASE
Material: 316L stainless steel, bead blasted
Diameter: 41mm across including crown, 37mm top to bottom
Lug to lug height: 45.5mm
Thickness 14.75mm to the top of domed crystal
Lug spacing 20mm
Anti-magnetic: 4800 A/m
Water resistance: 50 metres
Weight: 60 grammes without strap
Features: Screw back, drilled lugs
DIAL
Colour: Semi-matte black
Luminous: Hour dots, 12 & 6 Super Luminova C3
Day/Date: None
HANDS
Style: White painted, luminous filled
Luminous: Super Luminova C3
CRYSTAL: Hi-dome acrylic
MOVEMENT: Seagull ST-19 column wheel hand-wind chronograph
The PRS-5 is guaranteed for two years
A l'ouverture du colis première surprise, je m'attendais à ce que le boitier soit un peu plus gros, donc petite appréhension avant de la passer au poignet... Mais je suis sous le charme du boitier finition microbillé, de plus le High-dome est du plus bel effet et le strap qui m'est fourni avec est juste parfait avec cette montre!
Une fois au poignet ça marche nickel l'épaisseur du boitier aidant à lui donner une belle présence à mon poignet.
Une couronne siglée
Quelques photos de la mécanique
Comme la majorité de mes montres ont une entrecorne de 20mm, dès qu'une nouvelle arrive c'est parti pour une séance d'essai
Re: [Revue] Precista PRS-5
Tu devrais avoir honte de nous montrer ça ! :adore:
danlam
Message par danlam »
Très très chouette Joe, belle prise !
Amphibia a écrit :Tu devrais avoir honte de nous montrer ça ! :adore:
Surtout sur Tropic bleu!!! :adore:
EDIT: En fait nan... Tout lui va! :super: :super: :super:
landrover
Message par landrover »
Très sympa... Ca a un petit côté Andy Warhol :super:
landrover
C'est vrai que tout lui va bien...t'as pas un petit Strap de chez Jean dans les teintes marron bien tanné... :shock:
Alors celle-là, elle %)
Magnifique Joe et c'est vrai que tout lui va :super:
Re: RE: Re: [Revue] Precista PRS-5
landrover a écrit :C'est vrai que tout lui va bien...t'as pas un petit Strap de chez Jean dans les teintes marron bien tanné... :shock:
Moi j ai mais il n est pas à la taille de Joe. Joe, tu peux me l envoyer. Ou je passe la chercher la semaine prochaine. 8-)
:occasion: merci pour cette belle revue Joe, elle est superbe :super:
chezjoe
Merci à tous pour vos messages :respect: :jap: :respect:
Vraiment content de cette belle.
De plus aujourd'hui arrivée du fond de boîte transparent et d'un nato 2 pièces avec boucle déployante. Particularité de ce nato, il est doublé ce qui lui donne une belle épaisseur. Pour moi c'est nato 2 pièces sont parfait, je sens que je vais commander d'autres couleurs, pour le prix ça serait dommage de s'en priver :occasion: .
Retourner vers « Precista »
